Hi. I have a 2005 Beetle, and when I changed my low beam headlight today my high beam ended up burning out too, so I replaced it also.
Now when I turn my lights on low or high beam the low beam only comes on for both settings on the side that I changed.
The other side works as it should.
Could a wire have shorted out or something like that?
Are you sure you got the bulb hooked up right? Did you touch the bulb with your fingers?
The beetles do have some issues with the headlight plugin harness, which might need to be replaced.
I’m pretty sure that the wires are correct, but I’ll revisit that just in case.
I definitely didn’t touch the bulb.
Thanks for your response.
