So, my stepmom has an '05 Turbo and she has been experiencing ab issue with the headlights. Drivers side not coming on. I go and buy a new bulb (the quick solution... usually) well it was an HID so it was $100. Still nada. Then I look at the wiring harness on the bottom of the headlight assembly. Wires have lost all insulation. I cant seem to find a new harness.
Discussion Starter · #2 ·
Side note. This is the 8-9 wire harness that goes into the slide-out headlight assembly. Not the one that twists onto the bulb.
A major wiring harness of this type; is most likely only available through Volkswagen. I would go to your local dealer with your vin number; they should be able to find the parts you need.
Where is the general area; you are located? As far as I know; the USA spec New Beetles, did not have HID headlights, the rest of the world it was optional.
