i bought this Bug and the pass side head light was loose the locking ring was broke but since ii had no problem with it coming out i let it be. i had taken several long trips 300 miles one way and headlight never budged. I went to salem and on the way it not only came out it came it came off pulling the wires from the headlight and not the harness.when i finally got another headlight assembly i plugged it in and nothing so i stripped the tape away from the plug back to where it clsmped to the frame looking for stretched wire and so on nothing looks great now i just tried to tap into the good light wires to get it to work and then neither worked so I took wires off now the drivers side off when running on for night lights and only the high beam. i am at a loss any sugestions?
What year new beetle; are you working with? On the 2006 and later model issues; where the headlight plastic plug bracket, it gets warped from heat and this kills the connection to the lamp assembly. To fix this, you can remove the bracket/holder and just plug things directly into the lamp assembly.
Each side of the car has its own fuse for the lights. You may have just blown a fuse. Including a separate fuse for the hi beams and low beams on each side.
MKIV FUSE LIST
Top left to right by collum
1. Washer nozzle heaters, glove compartment light, memory seat control module (10A).
2. Turn signal lights (10A).
3. Fog light relay, instrument panel light dimmer switch (5A).
4. License plate light (5A).
5. Comfort system, cruise control, Climatronic, A/C, heated seat control modules, automatic day/night interior mirror, control module for multi-function steering wheel, control unit in steering wheel (7.5A).o,
6. Central locking system (5A).
7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
8. Open
9. Anti-lock brake system (ABS) (5A).
10. Engine control module (ECM): gasoline engine (10A); diesel engine, Model Year 2000 > (5A).
11. Instrument cluster, shift lock solenoid (5A).
12. Data Link Connector (DLC) power supply (7.5A).
13. Brake tail lights (10A).
14. Interior lights, central locking system (10A).
15. Instrument cluster, transmission control module (TCM) (5A).
16. A/C clutch, after-run coolant pump (10A).
17. Open.
18. Headlight high beam, right (10A).
19. Headlight high beam, left (10A).
D
20. Headlight low beam, right (15A).
21. Headlight low beam, left (15A).
22. Parking lights right, side marker right (5A).
23. Parking lights left, side marker left (5A).
Bottom left to right
24. Windshield and rear window washer pump, windshield wiper motor (20A).
25. Fresh air blower, Climatronic, A/C (25A).
26. Rear window defogger (25A).
27. Motor for rear windshield wiper (15A).
28. Fuel pump (FP) (15A).
29. Engine control module (ECM) gasoline engine (15A); diesel engine (10A).
30. Power sunroof control module (20A).
31. Transmission control module (TCM) (20A).
32. Injectors: gasoline engine (10A); diesel engine (15A).
33. Headlight washer system (20A). Open
34. Engine control elements (10A).
35. 12 V power outlet (in luggage compartment) (30A).
36. Fog lights (15A).
37. Terminal (86S) on radio, Instrument cluster (10A).
38. Central locking system (with power windows), lugging age compartment light, remote/fuel tank door, motor to unlock rear lid (15A).
39. Emerggency flashers (15A).
40. Dual tone horn (20A).
41. Cigarette lighter (15A).
42. Radio (25A).
43. Engine control elements (10A).
44. Heated seats (15A).
Fuse arangements in fuse bracket/battery:
S162. Glow plugs (coolant) (50A).
S163. Fuel pump (FP) relay/glow plug relay (50A).
S164. Coolant fan control (FC) control module/coolant fan (40A).
S176. Relays panel interior (110A).
S177. Generator (GEN) (90 Amp.) (110A).
Generator (GEN) (120 Amp.) (150A).
S178. ABS (hydraulic pumps) (30A).
S179. ABS (30A).
S180. Coolant fan
i figured out tonight that unlike american cars with one fuse for the headlights the bugger has 4 so i been driving with one hheasdlight for 2 weekscause i was ignorant and probibly should have checked the fuses reguardless i only learned as i had to go to the store and had no lights thats when i checked the fuse 's. and thanks to my brother Marine that came thru pretty quick but then hes just one Marine helping another. thanx Brother
