I thought I saw it somewhere in here, but I"ve done a search, and it comes up nowhere.
HOW do you get the headlite switch out so I can ATTEMPT to disable my DRLs?
tks.
Steve
Discussion Starter · #2 ·
I found out how to do it. (simple as hell).
Needless to say, MY 2002 beetle does NOT turn off the DRLs by simply bending over the tab as stated in many posts...................BUMMER....................
:mad:
Riviera Blue
Why not just pull the relay? I did that on my 03 Jetta I had when I did an HID swap. I'll probably do the same on the bug when I get the fogs working again, because VW doesn't understand how fogs work.
I bent the TFS pin.
Is the B pin that you state, marked as visibly/easily as the TFS pin behind the headlite switch as well? (or does someone have pics?)_
tks, Steve
Success. Success. I rebent the TFS pin back up, and bent down the B pin. No more DRLs! Yaaaaaaaay!
One minor peave down the drain. Onto the others.
tks for all the help!!!!!! :D
