1 - 10 of 10 Posts
· Registered
A sweet smell, or steam out of the hvac vents; would be a common sign of the problem. A pressure test,,is the best way; i have found, to pinpoint hard to find, coolant leaks.
· Registered
2004 Beetle GLS Convertible 1.8t Auto
So if you have a heater core leak and no moisture is found on the carpet, just where does the coolant go? Would it go out the Evaporator drain?
Sent from my SM-G998U1 using Tapatalk
In the case of my leaking heater core, the symptoms were coolant smell in the cabin and a haze on the inside of the windows, especially when in defrost mode. My carpets never got wet. The heater core is in a "well" inside the HVAC box, and it seems to me that there would need to be quite a bit of coolant in the well before it would leak out onto the floor of the car. When I took my leaking core out, there was just trace amounts of coolant in the well, that could be wiped out with a rag. Here is a picture of my leaking core - enough to be noticeable when driving the car, but not dumping coolant out.
Automotive tire Motor vehicle Gas Grille Automotive exterior
Tire Automotive tire Hood Motor vehicle Automotive lighting
· Registered
I just may have an issue with they blend doors. Not sure till I get a closer look. I was mainly curious where the coolant ends up. I was thinking it would share the Evaporator drain, assuming it wasn't plugged up. Which, I made sure mine wasn't.
· Registered
What symptoms are you experiencing and have you tried a cooling system pressure test?
I haven”t had to do a heater core replacement (yet); since the heater is not designed like à evaporator, maybe that is why there is no drain (like is needed for the a/c)?
If you suspect the heater core; you could bypass it and see if the coolant loss or interior symptoms disappear?
· Registered
Discussion Starter · #7 ·
I think I had a small leak as I would smell moisture in the cab. The heater would also not get very hot and take quite awhile to get warm. Awhile back I added some Blue Devil coolant leak additive that seemed promising as it claimed to react differently and create a chemical seal on leaks. Anyways, both heater core hoses get hot.
I'm still also having overheating issues only at idle. Thermostat and water pump have been replaced already. I'm leaning towards two different issues. I'm thinking I need to still burp air from the coolant system and that the blend doors is missing the foam covering to seal them as I've seen in so many YouTube videos.
Thoughts?
· Registered
This has been going on for quite awhile; this is a new thread (again), without the whole history of the overheating issue.
Why did you put the blue devil in originally; was there a specific cooling leak, that you were aware of? Did you pressure test the cooling system?
If you are thinking the heater core is leaking, you could bypass it and see if the smell, overheating issue goes away?
Good. video to review:
· Registered
Discussion Starter · #9 ·
This is a new thread because it's a new problem. Previous issues were addressed by replacing the water pump and radiator thermal switch.
The Blue Devil was put in because I was pretty sure the heater core had a leak as the previous owner had it bypassed. I isolated the heater core with a pressure gauge at one end and a Schrader valve at the other. It was verified to be leaking. After the Blue Devil was applied I performed the danger test and it would hold pressure (not leaking).
The original question I posted was informational as I never found any moisture leaking inside the cab.
· Registered
Well, you might review the checks shown in the video; see, if you notice anything, that indicates a problem? I usually, vacuum fill the cooling system and eliminate any possible air in the system, that way.
In a possible process of elimination; did the idle overheating issue, happen before the heater core was bypassed or after it was sealed with bluedevil, hooked back up again? As noted: if the heater core is suspect; you could by pass it again and see if things act differently?
When, you say “over heating “@ idle; how is it acting (boiling, fans kicking on, etc) and what coolant temps are being shown on a scan tool?
So far on the cooling system; what have you replaced or “fixed”:
Water pump
Thermostat
Flush/fill coolant
Sealed leaking heater core
Coolant temp sensor
Fan switch
1 - 10 of 10 Posts
