Well, lots of different things, problems going on at once; i would start by removing enough oil, to get the oil levels correct (drain to a clean oil pan; then you can put some back in, if needed).
Next, would be the coolant leak and levels. Normally, VW’s use their own specific g12/13 coolant; that is pink or violet in color. If you mix the typical green and pink coolant types; it can cause a thick coagulated reddish mixture, which shiws up in the coolant bottle and this can cause, overheating and cooling system problems. If this happens, the coolant will need ti be drained and the system flushed, cleaned out with dish soap like Dove, fresh water and flushed until all the junk is out, water clear. We can discuss more cleaning details; if this is the case. Fresh coolant would be needed; using one type of coolant and init mixing incompatible types together. Peak sells a vw spec pink coolant; which is a affordable alternative to other German or VW brand coolant.
Available premixed or concentrated; needing to be mixed with distilled water 50/50.
For the coolant leak, a cooling system pressure tester; can help pinpoint the source of the leak.
If no leaks are detected and a head gasket failure is suspected; you can rent a combustion leak detection kit, from a auto parts store and a compression tester as well. This would help you determine; if there is a head gasket issue or low compression.
Sent from my iPhone using Tapatalk on
