How do i know what pump i have. They sell a 4.8" and a 5.4" outer flange pump seal what one do i have? AND THE PUMP I HAVE HAS NO TUBES ON TOP JUST A PLUG. I HAVE YET TO SEE A NEW ONE WITHOUT ANY TUBE OUTLETS FOR FUEL?
Any good auto parts store or vw dealer; should be able to get you the right fuel pump. Mine was a VDO unit; if you search, using your VIN #, you should have not problem getting the correct one. The fuel pumps; have a part # on the top of them; that is also a way to identify the correct one.
You can search for parts on Bosch's website:
Bosch Vehicle Part Finder
They list yours as :
Bosch Part #: 69740 Fuel Pump Module Assembly
For VDO/Siemens (my VW original pump was a VDO OEM unit):
Search here:
VDO Webcatalog
They list yours as:
VDO PART # : 405-058-005-011Z
Engine Code: BPR, BPS
3 bar, without tank sender unit, Petrol
Both of the above part #'s are listed on amazon.com with the VDO being less expensive; hope this helps!
different fuel pump also
i have the same problem... i have an erratic fuel gauge so i looked under the seat to attempt to check resistance on sending unit and possibly clean the contacts and was surprised to see ten bolts and only a plug on top... no ring to unscrew or anything... nothing like all the vids ive seen on youtube... i think the difference maybe that we have metal fuel tanks... i dont believe those part numbers will work in our cars because we dont have the black ring ours are different... my car is a pzev maybe thats why it has a metal tank or idk... or a pzev fuel pump? im leaning towards metal tank...
The part number; should be on the pump itself or you can look on vw's parts site, use your VIN #, to confirm you get the right part or call your local dealer with your VIN and they can confirm as well.
https://parts.vw.com/
Just found out my problem now is I need a new fuel pump. I have verified with the dealer I need part number: 1J0-919-051-N
My 2010 has the METAL TANK, which just happens to be on avg DOUBLE THE PRICE of the one for the plastic tank. VW Dealer wants $823.00 for the pump & $320.00 to install = $1123.00 total for a frikin fuel pump!
SOOOOOOO, does anyone know of a cheaper way, a cheaper version, ect...?
I found this one on ebay:
New Volkswagen Beetle Jetta Electric Fuel Pump With Metal Tank VDO 291000010510 | eBay
@ $365.15.
Says it works for the 2010 w/metal tank, but will look at mine later today to make sure.
Do you think if this will be ok or know of a cheaper way to go?
I may be selling this money pit soon, so not planning on paying no $823.00 plus the 300 for labor.
I put the fuel filter in about 1 yr ago, and hoping I can do this myself too? BUT $823? RIDiculous!
NOTE: I would love it if someone could explain to me WHY they made one w/plastic and one w/metal tank in the same year?
My fuel filter alone cost over $50!
THX!
