2000 New Beetle - door lock switches check out OK. Driver door lock rocker switch will not unlock the passenger door. Is there an identified and known issue here, VW technical bulletin or other or a specific wire in the door jamb I should be looking at for a breakage?
The passenger side door lock switch works fine and all the electrical accessories in the car work properly.
Before I pull out my electrical meter and take the door apart I was just looking to see if the cause and solution may already be understood in our community of owners .
Andy
Andy
