P0352 - Ignition coil B
P0354 - Ignition coil D
P0441 - Evap improper flow
P0456 - Evap small leak
Not sure what engine we are talking about here? Small detail that might be helpful.
Assume you have a few coils coils bad or some sort of secondary ignition problem??
Not sure about 2005 but I know many years had recalls from VW for faulty coils.
Evap codes could be something as simple as leaving the gas cap off or loose, a bad gas cap or a broken hose or part in the Evap system. Do you know if these are current codes? Not likely related to the coil problem.
Also have you had any damage to the lower right rear bumper/fender area? The main Evap canister is mounted back there and can become damaged if the car is hit even slightly in this area.
Sorry about that. 2.0
No known impact to right rear.
I cleared codes and am driving to reset monitors.
Light has not returned, yet.
