Hi guys I need your help. My clutch is only about 6 months old. It grabs really good. The tranny is not popping any gears out so I believe tranny is ok. As I was driving 2nd 4th and 6th gear suddently did not want to go in. As I stated it doesnt grind when I try to put the gears in. its almost as if the shifter moved. Any help would be appreciated.
It does sound like a cable or shifter issue, especially if 1, 3 and 5 are working fine. My suggestion would be to try and figure out exactly what broke or moved *BEFORE* trying to adjust it away. The issue could be at the transaxle end or at the shift lever end.
Ok thanks. I never dealt with something like this so I wanted some input. I will look at the cable and see if it needs adjustment.
Peace Love & T.o.D.
If you have a 6spd manual, you must be driving a TS.
Look up on youtube, MK4 shifter adjustment. There are a number of videos on the subject. I think Dieselgeeks the best video showing the adjustment method.
