Anyone know that the hose circled in red is called or where I would find it in a parts breakdown. It is hooked to the bottom right of the long silver piece and is a hose that goes down toward ground. I noticed it is sucking in a little while car is on. Is that normal? Still having vacuum issues with the car. Had a coolant leak got that all fixed, now I think there may be either a vacuum leak or exhaust leak on the back of the engine in turbo area. Turbo makes like a hiss noise when under hard acceleration. Thanks!!
The hose is connected to the very end of the intake. Makes a slight bend and goes down toward ground into a larger hose.
