Here's my list of problems. The tachometer,speedo,fuel gauge and none of the lights will work on the instrument cluster. The only thing that works is the odometer. I pulled a working cluster from another 98 2.0 automatic and still no luck any suggestions would be greatly appreciated. I've also checked the connections on the back of the cluster. :confused:
Have you checked fuse 11? That is the one for the instrument cluster, although the wiring diagram is not clear about exactly what it powers.
I'm going to recheck it and others can't hurt
My other 98 the tach and fuel works along with the lights (temp check engine battery and so on ) but no speedo
