i have refreshed my ECU with revo and have changed the original DV to forge 007PA.
when i check the ecu with using vag-com , there is always false code in it "17705 - Pressure Drop between Turbo and Throttle Valve (check DV!)"
I have serviced the forge DV. but false code still remain.
i am using the green spring in forge DV.
shall i change the green one to another strong spring?
any idea ? pleaes help me. thanks.
ps: my beetle is 1.8T AG4 AWU
20V GTRS
Try and put your stock DV on, clear codes and see if it comes back. Make sure all connections are tight and check the vacuum line going to the to ov the DV for vacuum leaks. This will at least help rule out if it is the DV or not.
thanks ,
i've change to stock DV 1 day ago.
but still meets the 17705 error code after i clean all the error code.
the REVO dealer told me that is REVO'S bug.
because another car which also refreshed by REVO met the 17705 too.
