Hi all. I have a 99' 2.0 that is having a problem with the front driver side caliper sticking. I have searched and read many fixes for this here on the forum but, I can not seem to get past this. These are the things I have done so far.
1) 4 brand new calipers. (2)on this problem side, thought 1st one was bad. Ensured piston moves freely, also slide pins are free and lubed.
2) Replaced master cylinder (2) and power booster. Bench bled masters twice.
3) Ensured that there is some relief in the booster rod from pedal.
4) Replaced all brake lines and hoses including master to abs.
5) Replaced all wheel bearings and drive axles.
6) Checked caliper bracket for misalignment. No restrictions, caliper slides freely until pressure applied. Open bleeder and fluid comes out and caliper will release with use of a clamp.
I think there must be a problem in the abs system, which is not currently working. No light on dash, all wheels lock and slide on dirt/gravel road. I have checked all fuses and relay, all ok. I do not have vag com yet, will be ordering soon. Is there anything I may have missed? Driving me nuts.
Thank you for any suggestions.
