JOE CAT BEETLE ADDICT
I have a 2003 beetle turbo
I want to put Lexus 7.5 wheels 42 offset
I can buy the adapters
that are 25mm and 30 mm
- they said that i should put the 25 up front and the 30's in the rear?
Thank you they will be 18" wheels with 215-55-18 tires....
Thank you !!
whats your thoughts and how will it look and or rub?
Joe
VAG, it's a lifestyle...
How big are the wheels? 17, 18?
With an effective et of 12 and 17 (respectively) those are going to be sticking out past your fenders a bit.......
That offset is way too low (with the spacers) and those tires are way too tall (over 8% difference from oem).....you will have all kinds of clearance problems if you use those.
