So I was bolting the engine cover back on when I evidently tightened one of the bolts too hard and twisted it off. Now the thread is broken off inside and I have one loose bolt holding the cover on. Anything I can do to get the broken piece out?
Wife's 01 1.8T mechanic
You might be able to switch to the 2001 and later style that simply pushes/pulls on/off with no nuts. Otherwise, drill out the broken bolt, tap the mount for new hardware.
Is there anything left sticking out? If so, you could have someone weld a bolt back on it, unless you have a welder, I'd try that before I used an Ez out.
Sometimes, you can do the same thing with JB weld, but you have to be pretty careful not to get it into the threads.
Older but not Wiser
ill be in lexington ky on thanksgiving. ill check it out for you then if you want.
-jd
