1 - 20 of 22 Posts
Hi! New poster, but have been stalking for about a month:eek: I purchased my 2000 1.8l manual about a month ago. 91000 miles, timing belt and water pump have been replaced. It recently sat for a few days and the battery died. Couldn't get it to jump, so I went and bought a new one and it would start, but sound crappy. The coolant light came on so I added more and the oil is funny colored. Is it my head gasket?! There is white smoke coming out the back. I know all of this usually means the head gasket but I don't understand how a dead battery could lead to that... Any help would be great!
At this point; you don't want to run the engine, you could destroy the head and bottom engine bearings (contaminated oil will not lubricate the engine properly). You could do a leak down test; this does not require, the engine to run; so, it would not potentially hurt the engine.
More info here:
http://newbeetle.org/forums/1-8-liter-turbo/78633-water-leak-possible-cause-found.html
Let us know; how experienced you are in auto repair and if you are going to do the work yourself or have a professional handle the job. How does the oil look and what color is it or how does it feel in your hand (milky, gray, watery, slimy, etc; has your coolant been needing topped off lately)? I would NOT start or drive the car; until it is properly diagnosed/repaired or take it to a professional shop to have the problem evaluated (don't drive it in; tow it in). You may have caught the problem; just in time before any damage occurs or possibly things are already damaged. Hopefully, everything is ok; only through a inspection of the cam bearings and crank bearings; will you know for sure.
If you have anymore info; as to what was happening up until this point and any other issues or symptoms have been going on... let us know! Things seem to be pointing to a head gasket but you need to test, diagnose the problem to know for sure.
Thanks for your respnse! Well... I changed the battery myself... that's the extent of my auto repair knowledge. :( The oil is milky and it looked like it had brown specks in it when I wiped the dipstick. I had to replace the coolant today and I've only driven it about 200 miles since it was last filled. Should I try the head gasket sealant? How much will it cost to replace the head gasket?
You need to have the problem; properly diagnosed! Having a leak down test, of the cylinders/head gasket; would probably be a good next step to confirm the problem. How much coolant; did you "replace"? I would not drive or run the engine; until you figure out the problem. Can you post some pics; of how the oil looks? It sounds like water is in your oil; usually, a sign of a head gasket leak/failure. Head gasket "sealants"; are usually just a band aid and a normal professional repair, is the way to go. After the head is removed; having the head, fully tested, and repaired (if needed), is the correct way to repair the problem. Fix it right; don't cut corners and it will save you money in the long run! Do it once and do it right! Do you have anyone to help or have a shop, you trust... that you can take the car to?
I can take a pic in the am. I just moved to VA Beach and I have no idea where to take it. I was going to call around tomorrow. I really love this car but if it's going to cost more than a grand to fix, I'm probably just going to have to get a new one:crying:
Ouch; doesn't sound good! You might post up a question; as to where to take your car and see if anyone in your area, has some recommendations! Hopefully, someone can point you; in the right direction! Man, sorry about all your problems; right, when you just moved somewhere new... ugh! :(
Discussion Starter #9
Took it to the closest shop and the guy said it was the intake gasket or the head gasket and they couldn't be sure unless they took my engine apart... a 5 hour job at $112 an hour. That didn't sound right to me, so I took it home. Going to call around tomorrow.
Everett Street in May
FYI, a simple vacuum test can confirm if the head gasket is good or not. That shop was going to robb you, glad you tan away from them.
Reach out to "Warren" here on the org (that's his screen name). He is a long term resident of the area and can recommend a good VW shop.
Discussion Starter #12
I thought so too! I'm a female so I guess they thought they'd make an easy $500 if I was dumb enough to agree to that.:mad:
Discussion Starter #14
Got my car scanned. Had a P0302 code.Bought a new coil. Seems like a repair even I can do! I'm only seeing 2 spots where the coils go and all the pictures I'm seeing show four. Is this correct or am I completely missing something?:confused:
If you have the engine cover off, you should see the 4 coils.
Discussion Starter #18
Update: I replaced one of the coils, all the spark plugs, and the coolant temp sensor. The plug in cylinder 2 was so corroded that I had to pry it out. She's running perfectly now. No coolant loss and no milky oil. No CEL and no codes!!!! Thank GAWD for this forum!:D:D:D:D:D:D
I'm a little bewildered and curios; about what happened to the "head gasket" problem? :confused: Did you have someone else, check it out and test/diagnose it for you? Did someone in the area (referred to above); help you out? I hope; everything works out and your car is repaired correctly, running good! :)
1 - 20 of 22 Posts
