· Registered
Been lurking for ages just realised I've never joined so hello from Scotland
Ive got a 2003 pd100 alaska green tintop. Done la few wee bits to it but it's more of a daily driver than a seriouse project.
Wheel Car Volkswagen new beetle Tire Vehicle
· Registered
So, give us more info on your New Beetle; is it a V5 Sport model?
Na it's a tdi 5 speed pd100 model. I think it was a fairly base spec car on reflection I have actualy changed a few bits on it.
Outside
Just fitted the turbo sport bumper, the spoiler was a amazon job. Style 132 19x9 and 19x10s. Detachable tow bar ( it's a workhorse first 🤣) fitted a egr bypass and upgraded the ic pipes into the manifold to match also ran a boost gauge piping but not actualy fitted it yet.
Inside
a heated beetle leather out a 1c. (I had mk4 leather recaros out a 4 door in it for a while but i got sick of not being able to fold the front seats.) I kind of fancy mk1 or 2 tt front seats because the 1c comfort seats are rotten compared to the recaros. 3 spoke mk4 gti wheel, I've been working on a 3 gauge holder for the dash I plan to run water temp, oil pressure and boost. Also fitted the Ali express doubldin din head unit dash and stereo. Color coded bits of the dash to match the car.
Underneath is fairly standard. Fitted cheap coilovers all new bushes, bearings, turbo spec hubs and brake calipers with 312 drilled and vented disks. Painted the calipers vrs green.
Tire Wheel Car Land vehicle Vehicle
· Registered
PD 100, that would be diesel, correct? I like the characterization of “tin top” , so many people have issues with sunroofs across all manufactures that I’ve decided that I will not intentionally buy a car with a sunroof ever again and definitely not a “pano” roof. After the first couple of weeks of having a sunroof the novelty wore off and I never use it anyway.
· Registered
Yeah man in the uk the pump duse turbo diesel engines seem to be charicterised by the power output. There's loads pd100/pd115/pd130/pd150 to name a few. but my one was the poverty spec base model car far as I can see.
Uks the same it mainly rains here or is just cold most of the time proberly between - 3c and +10c aside from a month in summer where it'll maybe hit 30c.
The tin top comes from when i owned a mk1 golf/rabbit. Tin top or rag top was how they were described on the forums I kinda liked it so it stuck 🤣
· Registered
My wife has an 01 beetle tdi with the alh Diesel engine, my daughter has an 03 Jetta diesel with the same engine, I drive an 05 Golf with the BEW PD engine all 5 speeds and all with sunroofs.
The beetle sunroof has a small leak, the Jetta sunroof opens at random times by itself. I pulled the sunroof fuse for the Jetta but I have not had a chance to track down the leak on the beetle other than clean out the drain tubes which did not help so it may be leaking somewhere else
