Hello, I'm new!
Hi Beam dash indicator light stays on and drains battery. Head lights work fine just the indicator stays on even when car is off. Also the clock and temperature indicator are scrambled, if there is any relation.
Does anyone have an idea, aside from the basic troubleshooting, fuses, etc.?
Moved to Questions, Issues, Concerns, or Problems with the New Beetle. Somebody should be able to help you out with your problem here.
I took a look at the schematic, and it looks most likely to be the headlight dimmer switch on the turn signal stalk. Try jiggling it and see if that affects it. If the light goes out when the dimmer switch connector is removed, then I think you have found the problem.
