Can someone who has a wiring diagram tell me which color wire is hot and which one is ground for the horns on a 2007 NB? I could probably figure it out but I would like to know without climbing under the car and probing around.
many thanks,
Glenn
Black with green stripe should be positive brown shold be negative and connect to ground at the headlight harness
The Book has it as two black with yellow tracers (+) and two brown (-), one each per horn, from July 2005.
M.
Thanks to all!! I appreciate it
Glenn
