Horn stopped working after replacing turn signal relay
1022 Views 2 Replies 3 Participants Last post by  red99
Hi,
Recently I replaced my turn signal relay. Shortly after doing so, I noticed my horn had stopped working. Could the horn problem possibly be related to the turn signal or is this just a coincidence?
I bought the replacement relay on eBay. It works fine and looks exactly like the old one, although it makes a different/quieter sound when it is working.
Thanks,
Frank
Well, you could put your old one back in and see if the horn works then? What brand was the relay; some people, have had problems with non oem relays/parts. You could also; hook up your horn to the battery and see if they work. Start with the basics; see if you are getting power and check your fuses. Check out the manual for troubleshooting and repair, info:
Volkswagen Workshop Manuals
The horn is powered directly through the ignition switch so it shouldn't be affected by any relays.
