I have an 01' 1.8t and one of the front indicators/blinkers has just gone. I want to replace it but I can't see how to get into the bit where they are.
On each front signal, if you look at the portion of the lense that is closest to the wheelwell, you will see a small tab. If you remove it gently, the Phillips screw behind will be revealed. Loosen the screw and the assembly will come out.
