I dropped a large item onto my 2012 beetle rear spoiler tonight and cracked it. (I'm so pissed!)
I have found replacement spoilers for under $100.
How do I remove the factory spoiler?
I assume it is just on with double sided tape?
Or are there any bolts that hold it on.
Any advice would be great!
Thanks!
If it's the same as my 2013, then it's fairly easy/kinda. LOL.
I replaced my OEM one with an aftermarket Dune style spoiler.
I first removed the inner trunk panel to see if there were any bolts holding it down. Yes. there are. 4. Forget what size. Probably 10mm.
Either way, I figured THAT was all that held the spoiler down.
I pried, and prodded, pried some more. Didn't really figure out what held it on. And after I DID get the OEM one off, I was in too much of a hurry to go back and actually look.
Needless to say, I just pulled on one side, till a big carrrunnnch, and it came off. I dont remember seeing any tape anywhere tho.
The replacement one Did utilize 2 sided tape AND, also the same 4 screws. (at least holeplacement anyway. Had to make my own lineup tools/bolts/studs.
Hope any of this helps.
Thank You so much for the advice!!!!
Where did you find the Dune spoiler!???
I might put one of those on instead.
rear spoiler
It's an aftermarket (made in China, if I remember correctly).
best ali.express, I believe, is the portal/website, etc.
The spoiler is fairly decently built. It utilizes MOST of the OEM bolting points, PLUS it has double sided 3m tape EVERYWHERE on the inside.
I heavy dutied (sp)/, mine up even more just to make sure.
The black outside paint is very nice. The red (to match), paint, it looks like they prepped the area/sanded, w/ 60 grit paper, and went from there. But I digress.
At some point I WILL have it repainted/done properly, and do a better fitment of it. (as always, I have no patience, so was in a hurry to get it mounted).
Good luck, have fun.
