UPDATE: OBD II/OEM Comp Scan Test results = what do they mean?
Just reviewed, in detail (word for word) the Invoice of work performed by the mechanic.
[background]: Since reading about the OBD testing (and reading a lot on the Ross-Tech website about their VCDS (VAG-COM Diagnostic System) Packages, I'm sincerely/seriously considering investing the $250 for the VCDS system that will work for this car (most likely this one: VCDS License with KII-USB Interface). And, since I'm not familiar (yet!) with the codes, I figure someone on this forum might be able to decode the results I see on the mechanic's invoice/work list.)
here's how it's written,
exactly! (Invoice was computer generated)
COMPLETE OBD II/OEM COMP SCAN TEST
P0420= CAT EFFENCEY LOW
16502/P0118= COOLANT TEMP SNSR HIGH
RESET CIRCUITS COMPLETE
AFTER DAY RETURNED & NEW FAULT
19537/P0381=ENG TEMP TOO LOW INTERMT
RESET AGAIN
CUSTOMER TO MONITOR SYSTEM
If someone can, and is willing to, explain what's written above, I'm more than grateful.
Also, if I'm given directions on where to help myself follow-up on the codes above (to learn more about the codes, their meanings, and how to deal with them), I'm more than capable (well, to a degree; I don't have a garage to do major work in! Nor a whole bunch of tools, but I'm willing to begin taking care of this car as best I can; leaving the major work to someone I can trust.
Again, I do look forward to hearing your reactions and comments.
MANY THANKS IN ADVANCE!
Glen
