Pls I need someone to respond to that question AND another one question does this car have only one drain plug for coolant (the driver side one) or is there another one for the radiator? Is using G13 ok if I flush the coolant? Thanks
I don't know about the drain plug, but here is a chart with fluid capacities: http://www.billswebspace.com/vw2004fluidcapacitychart.pdf
G13 should be fine and you shouldn't need to flush if its got G12 in it currently. But if there is another type of coolant then yes, flush it before filling with G12 or G13.
