How-To by Porkchop
How To Change Auto Transmission Fluid
Hi all:
There have been a few threads on automatic transmission fluid changes. However, the link to the great PDF document how-to has been broken for a while, so I thought I would share my recent experience.
My car is a 2000 with 2.0L engine - however, I believe all automatics are the same 01M transmission from 1998 to recently (2003 maybe?). If yours is a 4 speed automatic, then this is the transmission you have.
First off, get the car up in the air. You can't just use ramps because you need the car level to get an accurate fluid level when you refill it.
Hi all:
