how to replace this speaker ,how to get there.
Slide center panel towards windshield. Undo the torx screws below. Pull up.
Easy
Your best bet is to grab the part number off of the speaker housing and call the nearest VW dealer to see if they are even made anymore. You may be able to find some out of wrecked vehicles, but no guarantee they will last very long. I’d recommend replacing the speaker with after market speakers of the same size (if you can find them) or installing new speakers completely. If memory serves, you can fit a 3-4 inch speaker in there with a custom fabricated mount, but I was running a separate amp and had deleted the factory Monsoon system.Okay, this speaker broke down, do you know what it is, so that I can order it?
I don't know what exactly to buyI would just get a set of component speakers and do away with those. Better sound and you don't have to jack with that one. Plus you'll have better sound because you can now use the tweeter to help with the direction of the music. Instead of the sound bouncing off the window, now with the placement of the tweeter. You will hear the sound better because it's pointed at you.
yes , cabrio 2003Do you have a door speaker also up front? What kind of bug do you have
I don't really knowMonsoon or not?
Do you have an independent tweeter?yes , cabrio 2003
