No NB Yellow Trifecta :(
Here you go...
1) Turn on the radio, you should see the SAFE in the radio display
2) When you see the number 1000, key in your four digit radio code using the station preset buttons (1 thru 4)
3) The Press and Hold down the right side of the ">" Seek button for three seconds
If your radio code is correct and you did the above steps properly you hill a beep and the radio will switch to FM.
