add a turbo in your life!
1) when i eventually hit 20,000 miles on the beetle the vw maintenance schedule says you should check the tranny fluid level. my beetle has a five speed. were exactly do i chack this at?
2) were is the dust/pollen filter? under the dash maybe?:dunno:
Send Money
Not maybe, yes. Under the passenger side. Gently grab the center dash piece and slide towards you. After you get it off, you will see a few torx screws you can remove to get the pass. side dash piece off. You will see the filter under there. There are 5 or 6 more torx holding in the filter.
