2000 beetle 2.0 130,??? miles.
Running fine until one day last week, it was damp/raining/snowing out, CEL was flashing, not running good. Checked this forum and all signs point to a bad coil pack. I got a new Beck-arnley? one and installed it. Running worse after the new one was put in. I'm gonna swap the old one back in and see if it runs ok, when it's not damp out. If so I assume I got a bad new coil pack.
ANY other suggestions?
I only had to disconnect 2 tubes with pinch to remove connectors, the plug wires, and the auctual coil plug. Not sure what vacuum lines and metal conectors other people talked about when swapping coils.
