1 - 11 of 11 Posts
· Registered
Loosing my mind here people! I have replaced all the spark plugs and the coils on my 2003 Beetle Turbo 1.8L at least 4 times, but the coils keep going out. I will replace one and it will work for like 30-45 days and then go out again, since I did not replace them all at the same time they go out randomly! This is killing me do you think there could be something causing this besides the coils themselves? They are aftermarket, and not the actual Volkswagen brand but I bought them at an auto parts store not online or anything. PLEASE HELP!!!!:confused:
· Registered
This doesn't exactly answer your question but VW had a recall on these about a year ago and would replace them for free, don't know what they will do for you now that you have after market coil packs but it maybe worth a call to your local dealer.
What brand of coil packs and from who are you buying them? Just because you are buying coil packs from an auto parts store doesn't mean they are of good quality.
Have you had your car scanned for codes? it may help in diagnosing your problem.
K
· Premium Member
You are, I believe, referring to the Service Action Campaign, initiated in June 2004 regarding coil packs used in certain vehicles as defined by Circular and VIN. A copy is below
And as to the OPer's question. Cheap aftermarkets maybe, improper installation, must be some codes being thrown.
MORAV
· Wanna Walnetto young lady
This seems to be a recurring problem on some Beetles, mine included. I just ordered new coils from ESC Tuning. These are supposed to be the latest revised units. I also ordered the hold downs for them too. These will be the third set since I bought the car 3 1/2 years ago.:confused: Hopefully this will cure the problems.:)
· Registered
The latest coil packs have made all the difference in my beetle; I haven't had any failures yet and the difference was night and day. In the previous generations of coils; I have coil packs fail on me twice; this is a common problem. There are some types that are supposed to be better then others; I would contact your dealer first and see if your car is in the recall campaign. If not; I would upgrade to the better and less failure prone coil packs, you should be able to call your service dept at your dealer and they can tell you if your car is in the recall over the phone with your vin #. Keep us posted on how things turn out.
· Premium Member
Better yet!
Krash is correct. There were two coil pack recalls. Get it to a dealer, have them run the VIN for open recalls, then register with VW to get recall letters.
You can check for open recalls online with your VIN, go here -
VW Owners Portal < Volkswagen of America
You can call and update Ownership at this number
800 822 8987
Now, there is no excuse not to do both! (lol)
MORAV
· Wife's 01 1.8T mechanic
I should note that I had to replace a coil on my wife's 01 1.8T a few years after the first recall. When it went in for the 2010 recall, I demanded that they give me back the coil pack I had replaced. Good to have a spare...
1 - 11 of 11 Posts
