I've read a few of these posts and some are old but I am going to post this anyway as I had this problem this week and found the solution after much struggle. It seems if you remove the key from the ignition, then move the steering wheel, it locks to the point that you cannot restart the car or turn the ignition with the key. Here is the fix.
First, get out of the car, close the door and lock it so you are basically starting over. Unlock the door and get into the seat. Put on your seatbelt (yes you must do this), press down on the brake pedal, pull the steering wheel slightly to the left and turn the key. Should work. Worked for me. DAB
