21 - 22 of 22 Posts
Nope..
Sounds crazy...
WIth the door closed and depressing the button do you hear any noise or sound of the motor jumping (a quick jerk)?
yes I have the same problem as well as a Voltage Leak and battery was going flat through the night. It was the right door lock that was shorting. So now same problem as you left windows are intermittant. I believe after talking to an expert Auto Sparky that its something to do with the immpbiliser not communcating with the windows? When you lock the doors either with the key or fob, it will put up the windows first. Therefore the whole issue is comp[ex and that all works from the large box behind the fuse board. Has two connectors in it.
21 - 22 of 22 Posts
