I have a 2002 New Beetle 2.0 non-turbo automatic. Thinking my speedometer problem was a result of a faulty speedometer, I bought a junkyard speedometer, took it to the dealer, and had it installed and programmed. I later found out my speedometer problem came from the speedometer drive gear (which I replaced), so now I'd like to have my original speedometer (with the correct mileage on it) back in the car.
Here's my question: Since the original speedometer was programmed for my car and there's nothing wrong with it, can I just put the old speedometer into the car and expect it to work? My question is really, is the car programmed to the speedometer in some way, or is the speedometer programmed to the car? If the latter is true, then I can change back to my original.
One collateral problem from my speedometer change: The dealer did not ask me for all my keys, and they did not tell me the keys would be reprogrammed. They took the car with the key I gave them, and now my second key, the fob key, does not work. Again, will this problem be resolved if I put the original cluster in the car?
Many thanks in advance...
