Greetings.
I have a 2007 Beetle convertible with a bright light dash indicator that stays lit always. Stays on when the car is off and drains the battery. Headlights work properly but the indicator light will not go off. Does anyone have an idea how to disable the lamp with fuse or other wise? Thanks:)
I would try to figure out; WHY the light is staying on. The speedo might be damaged or there could be a problem with the wiring, turn signal stalk (that turns on the high beams), relay or headlight related components, that is causing the light to stay on. When you say this light is "always on"; are you referring to the the "high beams" indicator or something else? A picture of the speedo in question; would be helpful, to see specifically what you are referring to. I would start by scanning the car with a vw compatible scan tool and see if there are any trouble codes. Fix the problem; don't bypass the issue! Fix it once and fix it right!
