Hi,
My 1.6 (petrol) Bug seems to enjoy revving itself when the clutch is down. The RPM will drop to about 500, and then the car will rev itself up to 1400-1500 (I assume to stop it from stalling?)
If I let it carry on, it usually goes away after about 30 seconds, and will start idling normally (~900 RPM), but after a period of driving, next time I pull up at a set of lights, it will start hunting again. The problem still happens when the engine has been warmed up too.
Anyway, for the actual question;
I did some code scanning, using a VAG-com, and the results are as follows:
17526 - O2 Sensor 2 - Open Circuit
17549 - Load Calculation Cross Check, Implausible Value
16556 - Fuel Trim, Bank 1, System Too Rich
I'm wondering if they're all related to the O2 sensor, or if there's more likely to be a vacuum leak or something similar?
The engine performs fine, gets between 30-35mpg (without driving particularly economically)
Thanks in advance,
Oli (UK)
Thanks in advance,
Oli (UK)
