My wife has a 2001 NB 1.8T with 105k on the motor. The head was rebuilt at 62k because the timing belt popped.
We've encountered a rash of issues recently, the most egregious being the flashing, red oil pressure light. Usually what happens is under ANY circumstances (idle, WOT, 2500RPM, turning, packed, going straight, under load, revving) the oil light may flash, twice, MAYBE three times and then go off. On RARE occasions, the flashing light is accompanied with the warning chime as well.
#1. There is NEVER ANY change in noise level from the motor. The valves don't tap too much and certainly don't tap louder when the light is flashing.
#2. There is never any hard sludge in the waste oil.
#3. Apparently sometimes, the coolant temp sensor would turn blue, after reaching normal operating temperature, during regular driving. However, this occurred in conjunction with the heater not blowing hot air AND the average temperature outside being below 10ºF. I replaced the thermostat today... (and the serpentine belt).
#4 The oil LEVEL is NEVER allowed to dip below the marks on the dipstick.
I know there are four basic reasons why this light usually flashes in VWs (esp 1.8Ts).
#1. Clogged pickup tube/generally dirty engine
#2. Faulty Oil Pressure switch/wiring at the switch
#3. Faulty Coolant temp sensor sending erroneous signals to a potentially...
#4. Faulty Gauge Cluster
I know the general rule is if the light comes on, STOP.
but the reality of the situation is my wife is going to wake up at 5:30 tomorrow and drive it 45 miles to work, then another 45 miles home at 18:00. She won't be taking my '84 Jeep with loose steering and she won't be calling out, renting a car, or doing anything other than her "normal routine."
IS THERE ANY WAY I CAN DIAGNOSE THIS IN THE DARK, 6 HOURS BEFORE SHE LEAVES FOR WORK?
If it's a cluster, fine... a faulty pressure switch, fine... but a clogged oil straw would suck (no pun intended). And it would suck more to lose the car.
Any easy way to tell if it's getting oil? I'm not going to have the car free to tear down until next saturday. :banghead: I don't have my pressure gauges either (stuck in storage with everything else I own (except a small bag of snap-on tools!)).
Thanks guys!
Thanks guys!
