I have 2003 VW turbo beetle. The driver side radiator fan motor still works, but the blades wheel has fallen off/detached.
This is a 4-wire unit which is much more expensive then the 3 wire unit.
My question is, is there anyway to "re attach" the blades to the motor?? I am not sure, figured I would ask. Thank you in advance for the help!!
Once the fan hub has failed (cracked, etc), it's done. The plastic will never be the same no matter what you try.
Time to find a replacement. I have one left over from a previous fan replacement, if you're interested.
