Is this possible?
1 reading
1.7K views 7 replies 7 participants last post by  jazzcat
#1 ·
Is it possible to use a supercharger AND a turbo on a 2.0L? Has anyone ever done it? I was just looking at the Neuspeed's set up and the S/C sits on top of the engine...why not put a turbo on the bottom part of the engine?
Hammer
#2 ·
VW has done that, and call it a Twin Charger. The super charger is used to get things moving off the line, and the turbo takes over for the high end.
General Doolittle used a turbo and supercharger on those huge rotary motors on the bombers used to bomb Tokyo. He needed the extra power just to get off the deck of the aircraft carrier.
#5 ·
"Twin charged"...Now that's something that needs to be seen IMO...I am looking at my car right now and shaking my head right to left...but what if? I am going to email Neuspeed and Garrett see what they have to say...then APR see what they have to say...Will keep you posted, I promise!:)
Hammer
#6 ·
This idea is a very old one and was actually used in a few production cars back in the 80's. Since that time it has shown up on a few 1st gen toyota mr2's and the meguires integra. In the long run the whole idea ends up costing more then it is worth and becomes more of a bragging rights " i have a twin charged car". In reality a properly tuned turbo/ or supercharged car will ended up running just as well or better.
To break it all down. In order to run a car like this you need a smaller supercharger and a larger turbo. So the motor has to be built and sturdy enough to handle high boost. There is no point in a system like this if you plan to run 8 psi since you can get that out of just a super or a turbo. You also need a clutched supercharger so that it can disengage when the turbo is spooled up. With this said. the superchager still needs to be able to handle the rpm's when the turbo begins forcing air through the supercharger.
Lastly, and the hardest part is the tuning. a system like this requires a stand alone management system, and someone with the knowledge to properly tune this.
All of this can be done, but it takes a lot more then simply bolting a turbo on underneath your neuspeed supercharger. All of these parts will be one of pieces and will cost you a hefty amount of money. In the long run, you would have been better off doing your research and purchasing a properly sized turbo with a equal length tubular manifold and air/ water intercooler. Running a GT series garret turbo would eliminate a lot of the lag associated with a turbo and allow you to run a slightly larger turbo for added boost. With an air/water you could run a short piping route and have a very responses and quick car to drive.
Now, if this is something you would really like to see, all the power to you, in my opinion it is simply easier to build a proper supercharger or turbo system from the beginning.
#7 ·
its to much trouble then its worth... and besides i really dont think we have enouph room under the hood to make one work... turbo is the way to go...
#8 ·
Hammer
not only is it possible but would be really fun to do
you should use nitrous to cool the intake charge or to spray around your intercooler and say you have a 3 power adder car :D
