Jump start may have had something to do with the problem.
In any event, you will need a scan tool that can read and reset airbag codes. Maybe you can get away with a simple reset, maybe you have a problem?
You WILL NOT be able to get any shop to look at the airbag code or reset if for under the cost of the tool I linked above, so buy it now!
You will thank me later, especially if you find out you have a seat belt latch problem, over $300 at the dealer, DIY with the purchase of the scan tool and parts for less than 1/2 of the dealer!
