Hey everyone! I just bought a 2000 2.0L Beetle today and have come across a few problems. The lady I bought it from had the car at the mechanic to fix the AC because it stopped working while I was in the process of buying it. While it was at the mechanic, they said that everything engine and transmission wise looked good other than a small oil leak that I shouldn't be concerned about. And the only things I need to have replaced within the year are the struts and breaks.
However i've noticed a couple things that are alarming me. First, after driving it about 25 minutes home from work, I noticed that it smelled like something was burning in the engine. They did say because of the oil leak, it would smell like burnt oil if I drove it for a while, but it still makes me nervous.
Also the driver and passanger side windows go down perfectly fine, however when I try to raise them, the driver side will stop midway and shoot back down or just stop all together. I have to continue to press the button upwards for it to go up, and only then will it go up VERY slowly. The passanger side window will go up, but it is so slow it seems like it will stop before completely closing.
And the very last issue is the car keeps pulling to the left. I had the mechanic check the alignment and he said it was fine and that I just had a valve leak and my tire was low, and it should be fine because he put some air into it. But it still seems to pull to the left. Now i'm wondering if I just need to get a whole new tire for the front?
Sorry if this is long and drawn out, but i've never owned a VW before, let alone a car this old. So i'm a little nervous that I just bit off more than I can chew with repairs. Any help would be greatly appreciated!
