Okay, I bought StinkBug, used, (a 2000 Beetle GLS 2.0)in 2004 from a Dealership. Came with one Key/Remote, and a valet key. The valet key would open the doors but wouldn't start the engine. I really don't think it was the original valet key for this car, although the key pattern, did match the lock! Bought a "New CUT Key (only) several years ago from, I believe "SideWinder" with a new virgin chip. It's been sitting around the house for at least 5 years. A few weeks ago, bought a used "Remote Only" off of ebay. Doing research, I see that I need the 4 digit PIN to program the "KEY" with VagCom. I start looking around, and low and behold!!!! I FIND THE "SCRATCH OFF TAG" (hadn't even been scratched off !!) It was in the recess of the glovebox. It's been there for as long as I've owned the car. I'm estatic! This is going to work!
So.... I am, able to match the ebay remote to the car, following the directions on you tube. ie; (not using VCDS.) So, great!!
But... I can't seem to program the "KEY" using the VCDS with the Ross Tech instructions, with my "found" PIN CODE! It keeps saying it doesn't recognize the PIN. Yes, I did enter the 0 first.
Where with all other "Controller Info" on VCDS, will usually show a valid "VAG Number" and "Component" the Immobilizer Shows as follows:
VAG Number: Bitte Adress Component: e 17 eingeben
yes, spelling is correct.
So at that point when I try to log in, "Login-11" with my PIN, it fails at that point!
Long Post... but any suggestions???
Does anyone know if there is a way to retrieve the original PIN, using VagCom? Yes, I know about VAGTECHO, and I really don't want to go there. I'm thinking since the Valet Key was from another VW, (it had a tag on it that stated " 2000 Beetle, Blue with Tan, whereas my Beetle is Blue with Grey. Maybe the "PIN CODE" TAG" found in the glovebox was from another VW as well?
Am I destined to purchase the VAGTECHO software in order to retrieve the original PIN Code?
Or did the Dealership, somehow circumvent the original PIN and reprogram the Immobilizer??
