1 - 1 of 1 Posts
strange things are afoot
The Basics:
  • 2003 Jetta Wagon
  • WVW Germany built VIN
  • Reflex SIlver
  • 5 Speed.
  • ~148k miles
  • Power windows, mirrors
  • Black cloth interior, non heated seats.
Exterior:
  • IN PRO Smoked E-Code HeadLights w/fogs, LED City lights.
  • Back, rear and rear doors tinted 20% Llumar (DARK!)
  • Front doors Tinted like 35% (too dark)
  • Factory VW Steel Skidplate
  • LED turn lights on front fenders
  • Rear Fog light.
  • Front Aero Wipers
  • Front Winter Cover Set
  • Aspherical Mirrors
  • Rubstrips are painted with black textured truck bed paint
  • Short aluminum tiped antenna
  • Class 1 trailer hitch.
  • TT lift pads
Engine/Transmission:
  • Brand new complete T4 .216 Injectors - Installed @ 145K (have stock injectors too)
  • Rocket Chip Stage 3
  • South Bend Stage 3 Clutch with 17# Flywheel - Installed @ 145K
  • Wavetrac LSD - Installed @ 145K
  • 3.16 Final Drive - Installed @ 145K
  • CAT 2 Micron Fuel Filter
  • Timing belt was changed @ 95K miles w/IDparts TBelt Kit
  • Original Green Dieselgeek Racepipe
  • No EGR Cooler
  • OMI
  • 3” Catless exhaust with Magnaflow Muffler - Installed @ 145K
  • Dawes Device - Installed @ 37K
  • DG 5 speed short shifter - Installed @ 145K
  • Old Navy Oil cap
  • Dynaflow CCV
  • Frostheater
  • All filters (Cabin, Air, Oil, and Fuel Filter) are changed @ The 10k mile interval
Interior:
  • Never Smoked in
  • 2004+ Cupholder center console
  • Audi MK1 TT pedals w/Beetle S Dead Pedal.
  • Aluminum Trim Set w/ in Dash Cup holders.
  • Full Sized Glove Box
  • McNally A pillar Pod w/EGT/Boost Gauge (0-30psi), Needs a LONG EGT Probe, it has a stubby one in the EGR port.. doesnt read temp correctly.
  • Euroswitch
  • Monster Mats (Front & Rear)
  • Armrest with broken lid hinge (SHOCKING, I know)
  • Sunglass holder where driver side OS handle goes
Wheels & Suspension:
  • 15" Avus 2 wheels with Bridgestone Potenza tires
  • 16" newbeetle alloys with Snow tires
  • Koni FSD shocks, VR6 Front springs, Wagon rear springs will replace the coilovers
  • Audi TT front control arm bushings to be installed
  • Rear Rotors and Pads Replaced @ 145K
  • 337/GLI Front Brake kit (off a GLI with 35K miles) ( New Rotor/Pads) (Not Installed, may be for sale, I like my 15s...)
Body Condition:
  • Paint chips on front of hood.
  • A couple dings on rear Driver’s side wheel Arch.
  • Scratches on rear passenger side wheel Arch.
  • Tailgate has scratches under license plate holder and there is a small pea sized ding.
Issues:
  • Car needs a new front wheel bearing holder to replace the cross threaded/almost stripped carrier bolt.
  • will be replacing the control arm bushings, and ball joints and tie rod ends soon
  • Front Driver Seat is showing some wear (7 of 10), one of the arm rest hinges sheared off, though, it most likely can be fixed with JB Weld.
  • V-tex cover piece on steering column is missing.
1 - 1 of 1 Posts
