I have a lean code. It is a vacuum leak, it starts with 20 to 25% STFT lean after resetiing dtc. It completes all readyness settings to green however when driving. Light comes up while idling or braking.
When I squeeze the rubber hose from intake manifold to the Y tube connecting pvc and brake booster on top of the engine I hear somewhere a hissing sound and when measuring vacuum on intake manifold it reduces vacuum, but comes back when I keep the hose squeezed. I don't close it entirely off.The weird thing is that I cannot find any crack in the rubber hose part.
Also, when I press the brake pedal the vacuum reduces for a short period in time.
First: is it normal when squeezing this hose the vacuum should change?
Any clues where to look if this rubber hose by itself is intact?
Sounds like it may be the hard plastic tube / hose that connects to the brake booster. It is hard to see because it is buried under a lot of other stuff, but if you look closely at the brake booster, you will see that a hard plastic tube / hose is connected to the reservoir. Feel along the hose closely, and chances are that you will discover that it is cracked where it attaches to the brake vacuum reservoir.
Title User Custom
There is a plastic vaccum line at the end of the run towards the booster. It's appearing to have a tendacy of breaking along the outside of the bend making it hard to visually see.
I ended up replacing ours last year with a pre-bent/reinforced rubber line. I do not recall the part number I used unfortunately.
Vacuum leak
All thanks for the advice. I had a double leak. A small one in the valve to the air intake. This line is connected to the Y tube at intake monifold, the other end of the Y is connected to the brake booster. The plastic pipe was in a bad shape. So i repaired it by using vacuum re enforced rubber tube. I also glued the burned hole in the plastic valve. I will replace this one with a new one soon. My ltft is back where it should be and no cel anymore.
