Help! I have an 09 convertible 2.5L with a bad window regulator cable. I’ve ordered two different regulators and both have been incorrect. The window have a bolt that supports the AFT of the window and a clamp in the front. The bottom of the regulator rails have studs that go through the bottom of the door and nuts then secure them. The top of the rails have studs that go through the door and nuts secure them to the door. Lastly the metel door panel and door panel go on.. I can not find this exact regulator and there is no part number to be found. Vehicle was mad in Mexico and has time stamps from 08’ on some of the parts . Please help !
Best solution is contact your vw dealers parts dept; they will get you the correct part, using your vin number. You can get the repair kit and save some money that way, rather then a full regulator replacement assembly. (Kit is about $100 or so; vs. $200+ whole assembly).
