Does anyone on the forum know the part number for this piece? I ordered one from a spares supplier and it was supposed to fit but is completely different from the original. The original piece has a bolt fixing at the top of the two rails and a bolt fixing on the two rails accessed from under the door. I'm getting frustrated!
Contact your local vw dealer with your vin number and they will get you the correct parts. Genuine vw parts are best quality for this and last the longest. The repair kits are the mist cost effective solution, which replaces the parts that wear out, break but it does require installation on the regulator panel. Getting the cables on the pulleys; is a bit of work but can be done.
