License plate bolt/screw size? (USA)
10K views 12 replies 2 participants last post by  bikergeek
I was in a similar situation; in my case, I had removed/installed the screws so many times, that they were falling out. The plastic plate mount; is not threaded but just plastic, so the screws make their own "threads". I couldn't reuse the old size screws; as the plastic was stripped out. I just went to AutoZone and got some black colored license plate screws, this created new threads in the plastic and they worked fine. Not exactly answering your question but I thought, I would tell you, what I found that worked for me.
Well, you might try; the kit that I used, again from Autozone.
The Hillman Group License Plate Mounting Hardware:
(in their "Needa?" line of fasteners)
Import M6.3-1.81
Part Number: 459820
Price: $ 2.49
Package Quantity: 8:
four screws and four plastic retainers
https://www.google.com/search?ei=r7...0.6635.8.8.0.0.0.0.163.772.0j6.6.0....0...1.1.64.psy-ab..2.0.0....0.DAtMnwRqYjs
In my store; it was in the area, that has license plate related frames, fasteners, etc. That is a good part number and you should be able to call ahead and confirm; they have it in stock. Good luck! I hope this helps! :)
Call ahead and ask them to find it; they can set it aside for you or order it online Special ordering it; is always a option. I’ve been ordering things from them lately; shows up pretty quickly and typically ships for free.
Well, I recommend; you try the Hillman kit that worked for me. I would call ahead and see if they have it in stock. Otherwise, you can just order it; I've noticed, that I have been ordering parts from Autozone and they will ship it to my house with free shipping, eliminating one more trip to the store.
Import M6.3-1.81
Part Number: 459820
