1 - 20 of 32 Posts
Does anyone know how to lower the roll over protection system on a 2018 beetle conv. Hit a sidewalk and it just popped up. Also, trying to figure out how to remove driver seatbelt to replace it as it locked up. Looking for directions or a video detailing.
Thanks
Good question, this info; is probably documented in the vw factory service manual (e.g. codes, sensor id, location, soft coding process, etc). You could join vw's eRWin online service, pay for 24 hours access and download the manuals you need. A factory vw level scan tool; like vcds by ross tech, maybe needed to do programming, soft coding for new parts and checking for trouble codes.
Historically, "crash" type sensors, may need to be replaced or shipped out, to be reprogrammed/rebuilt by a module repair specialist. Some sensors, can be "reset" using vcds; more research and checking for codes, is needed.
Since, the car is so new, i assume you have full coverage insurance; if you had a accident, have a insurance claim done and have it professionally repaired?
Let is know, how you want ti approach repairs and we can go from there.
Sorry took me so long, the car wasnt insured it wasnt supposed to be on the road and one of my kids decided it should be. Good thing it was a single car accident. I got the eRWin service and downloaded every pdf i could find. I dont see anything about lowering the roll over protection system or how to lower the roof manually so i can make sure the posts dont rip top as its opening.
Did you find the section for the convertible top; i would be looking for repair information. You will most likely need a vw factory level scan tool; like vcds by ross tech, ti read any trouble codes and possibly do some reset, programming or coding for new replacement parts. Your situation, is the first we have hears about top repairs or the roll over assembly being actuated. The roll over protection, maybe similar to a airbag and be a one time use part with replacement and crash sensors requiring resets or programming, after install. It sounds like more research and scanning for trouble codes with vcds, maybe needed. Beyond that, a estimate from a vw dealer and/or vw authorized body shop with the appropriate tools; maybe, a next step, if you cannot figure things out.
Yes the assembly is one time use but the dealership says its plug and play and its just 4 bolts. I ordered a dongle from ross tech waiting for it to come and yes i downloaded the pdf but nothing talks about lowering roof manually.
Here is a video, showing output testing for the new beetle; there is probably similar testing for the later models.
It maybe a case, where; the deployed roller over assembly and relayed crash sensors, has stopped the top assembly operation, until codes and/or needed repairs are completed, allowing normal operation?
By passing the inoperable top; to do the repairs, would be next? I javen't heard if thia procedure being done around here but there must be some way ( note: how the video; shows it being done by hand, bypassing errors in the top).
I recall seeing how to close somewhere theres some red cable or cord around where the passenger flap is in the video to release something so it moves freely.
Discussion Starter #10
I couldnt get the roof to open over the posts and I could only find one post about someone who was doing the same thing and the process he said to lower wasnt working. Someone replied to my question on his youtube channel and said they cut the post down so the roof would go over it so it could be removed which is what i ended up doing. Now my issue is the top and windows stopped working as the battery was disconnected. Ive been reading up on different techniques for the window which sometimes works but nothing is getting the top to move as of yet.
Did you acquire a vw factory level scan tool; like vcds by ross tech? I would read trouble codes and see what they are. If the battery went dead, i would charge it, replace if bad and you might try a hard reset of the ecu (touch positive and negative cables for a number of seconds, then reinstall). Historically, on older vehicles, you could temporarily restore functionality to an assembly; by unplugging and replug them in a control module,say for the convertible top
Discussion Starter #12
I currently have a launch x431 reader, I ordered a Hex v2 and am waiting for it to arrive. I did the positive and negative cables which gets the windows moving for a lil bit. I'll try and charge the battery some tomorrow.
Discussion Starter #15
I copied every file off erwin and it doesnt say anything about it. I'll check once again to confirm but as of now nothing.
Discussion Starter #18
Thursday,30,April,2020,12:20:07:55285
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: 3VW5DAAT5KMXXXXXX License Plate: NONE
Mileage: 240km-149mi Repair Order: none
Chassis Type: AT-VW32 (7E0)
Scan: 01 02 03 04 05 08 09 15 17 19 25 26 2B 3C 44 5F 61 75 B8
VIN: 3VW5DAAT5KMXXXXXX Mileage: 240km-149miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
26-Auto Roof -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
75-Telematics -- Status: OK 0000
B8-Elect. Roof 2 -- Status: OK 0000
Address 01: Engine (J623-DDSA) Labels: None
Part No SW: 06K 906 016 F HW: 06K 907 309
Component: R4 2.0l TSI H31 6242
Revision: 1EH31000
Coding: 411A00922424000F1000
Shop #: WSC 00066 790 00451
ASAM Dataset: EV_ECM20TFS01106K906016F 003003
ROD: EV_ECM20TFS01106K906016D.rod
VCID: 2D070874ED9C4133C8D-8078
1 Fault Found:
17165 - Databus
U1123 00 [047] - Received Error Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 246 km
Date: 2020.04.28
Time: 00:12:16
Engine speed: 788.50 /min
Normed load value: 5.5 %
Vehicle speed: 0 km/h
Coolant temperature: 87 ∞C
Intake air temperature: 40 ∞C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 13.420 V
Unlearning counter according OBD: 40
Acceleration: 0.000 m/s≤
Cruise Control System (CCS): status-Bits 0-7: 7
Cruise_control_shutoff_conditions_irreversible-Bits 0-7: 0
Cruise control system: temporary deactivation-Bits 0-7: 255
Accelerator pedal travel: 0.00 %
Cruise control switch actuation-Bits 0-7: 0
Cruise control switch actuation-Bits 0-7: 49
Readiness: 1010 0101
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 DP HW: 09G 927 158
Component: AISIN AG6 G3 202 3518
Coding: 010200000C000000000000000000000000000000
Shop #: WSC 00066 790 00084
ASAM Dataset: EV_TCMAQ250031 002009
ROD: EV_TCMAQ250031_002_VW23.rod
VCID: 04518DD01E96607B773-8050
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
Coding: F14B4016492300FB8F1302EB921B00412010F01A
Shop #: WSC 00066 790 00247
VCID: 75B7E01445CC49F370D-8020
2 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 246 km
Time Indication: 0
Date: 2020.04.30
Time: 00:02:18
Freeze Frame:
Count: 2
Count: 12
Count: 28672
Count: 16390
Count: 44544
Count: 0
Count: 511
Count: 0
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 246 km
Time Indication: 0
Date: 2020.04.30
Time: 00:02:08
Freeze Frame:
Count: 2
Count: 12
Count: 28672
Count: 297
Count: 45312
Count: 0
Count: 255
Count: 0
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 J HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1403
Revision: 00092000 Serial number: 0509847805
Coding: 032C0C
Shop #: WSC 00066 000 00076
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: EV_KESSYPQ35G_A02_VW31.rod
VCID: 3C21353026E6D8BB4F3-8068
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 5C0 907 044 AN HW: 5C0 907 044 AN
Component: Climatronic H08 0911
Revision: 00001K04
Coding: 2050019002
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_VW32.rod
VCID: 6FBBD27C27107323BA1-803A
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 190 D HW: 7E0 937 190 D
Component: BCM PQ25 Max3 H82 0762
Revision: B8082001 Serial number: 21017147190102
Coding: 7BAC692808AB080001FD3F3024C986D53DC2622F60006D70B2B054022800
Shop #: WSC 00066 000 00000
VCID: 2D070874ED1C4133C8D-8078
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 030519 05 54 0403
Coding: 02300A
1 Fault Found:
03020 - Local databus 2
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 246 km
Time Indication: 0
Date: 2020.04.28
Time: 00:12:39
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 AB HW: 5C0 959 655 AB
Component: AirbagVW10 503 0977
Serial number: 003LZM00NEMB
Coding: 0000424A
ASAM Dataset: EV_AirbaVW10SMEVW360 001030
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 72BDDB0834225ECB55F-8026
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y190001WH3G03
Coding: 30314A
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME1F4B5B60ZZZ3
Crash sensor for side airbag: front passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME1B4B5B60ZZZ0
Crash sensor for front airbag: driver side:
Subsystem 4 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME61514039ZZZN
Crash sensor for front airbag: front passenger side:
Subsystem 5 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME75494139ZZZ.
10 Faults Found:
9636379 - Actuator for Roll-Over Protection; Driver Side
B130A 1B [137] - Resistance Too High
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 246 km
Date: 2020.04.28
Time: 00:12:41
9636635 - Actuator for Roll-Over Protection; Passenger Side
B130B 1B [137] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 246 km
Date: 2020.04.28
Time: 00:12:41
9437211 - Igniter for Driver's Airbag
B1000 1B [137] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 246 km
Date: 2020.04.28
Time: 00:12:41
9437723 - Igniter for Passenger's Airbag
B1002 1B [137] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 246 km
Date: 2020.04.28
Time: 00:12:41
9438747 - Igniter for Seat Belt Tensioner; Driver's Side
B1006 1B [137] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 246 km
Date: 2020.04.28
Time: 00:12:41
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
B1007 1B [137] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 246 km
Date: 2020.04.28
Time: 00:12:41
9442075 - Driver's Belt Force Limiter Igniter
B1013 1B [137] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 246 km
Date: 2020.04.28
Time: 00:12:41
9442331 - Passenger's Belt Force Limiter Igniter
B1014 1B [137] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 246 km
Date: 2020.04.28
Time: 00:12:41
9572123 - Ignitor for Passenger Airbag Release Valve
B120F 1B [137] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 246 km
Date: 2020.04.28
Time: 00:12:41
9437979 - Igniter 2 for Passenger's Airbag
B1003 1B [137] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 246 km
Date: 2020.04.28
Time: 00:12:41
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5C5 920 976 M HW: 5C5 920 976 M
Component: KOMBI H72 0607
Revision: X0072001 Serial number:
Coding: 221E010000
Shop #: WSC 00066 790 00317
ASAM Dataset: EV_KombiUDSMM9RM10 A05809
ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
VCID: 3B23362C23E8DF83469-806E
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 190 D
Component: GW-K-CAN TP20 H82 0762
Revision: B8082001
Coding: 502001
VCID: 6889B960027EA41BFBB-803C
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5C5 920 976 M
Component: IMMO H72 0607
Coding: 000007
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6A8DC3681CF2960BEDF-803E
Address 26: Auto Roof (J256) Labels:* 5C3-871-601.clb
Part No SW: 5C3 871 601 A HW: 5C3 871 601
Component: VSG-MASTER 015 0353
Coding: 000000
ASAM Dataset: EV_VSGWEBASVW36X 005002
ROD: EV_VSGWEBASVW36X_005.rod
VCID: 2313EE4CBB5887436E9-8076
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 D HW: 5K0 905 861 D
Component: ELV-PQ35 H22 0240
Revision: 00000000 Serial number: 19000103220004
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X_VW31.rod
VCID: 313F1404F1A425D3EC5-8064
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0514742011
Coding: 01011101
ASAM Dataset: EV_HREntryHella 001028
ROD: EV_HREntryHella_VW32.rod
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0514749990
Coding: 010111
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 70 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 392F2C242554ED93545-806C
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Battery Volts: 12.7 V
PD
Temperature: 22.0∞C
Count: 2
Steering Angle: 0.00∞
Count: 1
SteerAng n.Init
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 200 D HW: 5C0 035 200 D
Component: MU-S-S-US H42 0475
Serial number: VWZAZ2W0821627
Coding: 02230500FF00000051220001001808009F0100D40020010002
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 1675C798780AE2EB997-8042
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 190 D
Component: Batt.regelung H82 0762
Coding: E1200A59
Shop #: WSC 00066 790 00076
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 024 0160
Serial number: 000003554140570
Coding: 02230502C21650107F1606C00000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_OCULow 002010
ROD: EV_OCULow_002.rod
VCID: 1471BD906EF6F0FBE73-8040
Address B8: Elect. Roof 2 (J256) Labels: 5C3-871-601.clb
Component: VSG-SLAVE 015 0353
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_VSG2WEBASVW36X 005002
ROD: EV_VSG2WEBASVW36X_005.rod
End----(Elapsed Time: 01:05, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
1 - 20 of 32 Posts
