1 - 11 of 11 Posts
Fordracinjunkie
I have a 2001 beetle sport ran fine yesterday. Today when I started the car I had a flashing check engine light. Checked codes here's what I got p0135 p0171 p0300 p0301 p0302 p0303 p0304 p0455 p0507 p1297. The car does run but is missing idling rough. Idle will go from low about 500 rpm to 2100 rpm back to about normal but still missing. Please help I'm new to beetles and it's my only car I have a scan tool that will do real time data if any other info is needed. I replaced timing belt and water pump about 8 months ago. Cleaned mass air about 2 months ago. Thanks this site is great!
I'm no mechanic. But, I know someone will be by soon to help.
Hope it's not too bad! :(
I would start by clearing the codes and seeing what comes back. Then you can use this site to look up the codes: Ross-Tech Wiki
Second Smileybug. Then unfortunately tackle one issue at a time as they come back. Keep updating forum and asking questions.
I had a fault code, missfire in #3 on startup. After replacing all wiring, coil packs and plugs, I was still getting the code. Mechanic friend wanted to pull and replace motor. Not worth doing on this one. Know what fixed it? A $12 bottle of oil additive and a different oil weight. lol. Its been running fine for a year.
Good luck. It takes patience.
16555/P0171/000369 - Fuel Trim; Bank 1: System Too Lean
Possible Causes
## Mass Air Flow Sensor (G70) defective
## Intake System Leak(s)
Possible Solutions
## Check Mass Air Flow Sensor (G70)
## Check Fuel Pressure Regulation
## Check Fuel Pump
## Check Injectors
## Check Intake System for Leaks
## Check Exhaust System for Leaks
## Check Secondary Air System for Leaks
## Check Vacuum Pipes for Leaks
16839/P0455/001109 - EVAP System: Large Leak Detected
Possible Causes
## Gas Cap loose/missing
## EVAP System Leaking
Possible Solutions
## Check Gas Cap
## Check EVAP System
## Check to make sure EVAP purge valve is not installed backwards
The 300's are misfires overall and all 4 cylinders
16891/P0507/001287 - Idle Control System RPM: Higher than Expected.
Possible Symptoms
## Malfunction Indicator Lamp (MIL) active
Possible Causes
## Throttle Valve Control Module (J338) dirty/faulty
## Wiring/Connector(s) from/to Throttle Valve Control Module (J338)
## Vacuum Leak
Possible Solutions
## Check Throttle Valve Control Module (J338)
## Check Wiring/Connector(s) from/to Throttle Valve Control Module (J338)
17705/P1297/004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
Possible Symptoms
## Malfunction Indicator Light (MIL) ON
## Power Loss
Possible Causes
## Leaking Hoses and/or Pipes between Components
## Boost Pressure Control Valve (N249) faulty
## Diverter Valve faulty
## Throttle Body dirty
## Vacuum leak
Possible Solutions
## Check Hoses and Pipes between Components
## Check / Replace Boost Pressure Control Valve (N249)
## Check / Replace Diverter Valve
## Check / Clean Throttle Body ## Perform Throttle Body Alignment (TBA)
## Check for Vacuum leak(s) including PCV system
Most of the codes are triggered because of misfires.
There are two main possibilities for misfires,
Your plugs are not working properly (you unplug and look if they are in good or not)
Your coils are not working properly. You can understand if you try to do full throttle in low rpm.
First of all, change which one is not working then scan your engine again.
Lean condition is likely cause most of the misfire problems.
There is an intake air leak somewhere causing the problem.
Smoke test to find leaks, search YouTube for Scotty Smoke Test and do what Scotty does or build a tester from related video.
Fordracinjunkie
Discussion Starter · #10 ·
Just miss fire codes now
Down to just misfire codes p0300 301 thru 304. Checked plugs they look good. Idle is rough but when I rev it up it seems to smooth out. Seems to drive with normal power. Is it possible all the coil on plugs going bad at the same time. Is there a way to check the (cop). Thanks again
1 - 11 of 11 Posts
