Hi there!
The trunk weather stripping needs to be replaced on my 2006 convertible. Does anyone know what a good aftermarket weather strip that would work? The OEM is so expensive I was looking for an alternative.
thanks for any suggestions.
Loren
2006 Convertible
Palatine, IL
I am not aware if any aftermarket seals are being made; you might ask a local auto glass shop, to see if they know about any.
If new genuine vw parts, door seals are too expensive; there always seems to be some at junkyards at this point. My drivers side door seal was getting damaged from; my feet brushing over it, when getting in/out of the car. I went to a local pick/pull junkyard and found one in perfect shape, i think for less then $20. Here is a used parts search engine, to find used parts nearest to you and with contact info
